70 gt 350 convert ?s
Started by shlb69, June 22, 2020, 12:04:07 AM
shlb69
1) is the trans brace for automatic bare metal. 2) is the reinforcement piece on the bottom of the vehicle as bare ?
Quote from: shlb69 on June 22, 2020, 12:04:07 AM
The transmission brace was bare steel. If you want to get detailed you can reproduce the dark bluing where the separate pieces were welded together (from the heat of the weld) and or reproduce the stretch marks and details that took place during the bending/shaping of the longer piece
Quote from: shlb69 on June 22, 2020, 12:04:07 AM2) is the reinforcement piece on the bottom of the vehicle as bare ?
The convertible brace (this year and plant) that bolts between the drivers and passenger floor brace was painted the slop or batch color similar to one of the multiple tints that have been found on the shock tower support brackets, battery tray, coil spring covers and a number of other items at the front of the car. Often a darker grey with a tint of blue or green to, in some cases, almost black
Hope this helps
shlb69
That's what I thought but the brace only showed bare metal which threw me off.  In concourse trailer what is acceptable on trans brace.
Quote from: shlb69 on June 22, 2020, 08:54:16 AM
The trans cross member can be painted in MCA trailered if the paint shade reflects a close approximation of the original bare steel. Getting it to look close with paint is the trick. How you do it is the challenge. Many going for the historical look go with bare metal that has been tumbled and then covered with one of a number of rust inhibitor products available .
