Rebuilt Distributor and alternator
Started by Greg, April 15, 2020, 11:51:50 AM
Greg
Hello, an update....
I rebuilt the original distributor in my 65, turned out really nice I think.  Working on the original alternator now, I see why they shelved it as one of the diodes had come loose from the board.  It's all cleaned and ready to reassemble once I have the new brushes and bearing.
Shelby's and Fords from Day 1
6S1568
Quote from: Greg on April 15, 2020, 11:51:50 AM
It may not matter to you if the distributor is clocked wrong. If it does then you have it installed a couple teeth off compared to factory I suspect. It will function just fine if already timed and ready to go.  From the factory the cap clip is typically approximately close to center forward when timed . At least that is the way they are clocked from the factory .The spark plug wires are position best from that orientation also given that was how they were cut so that they would accommodate that factory clocking position . Of course that factory position makes it somewhat difficult to clip and un clip the cap clips and is why many install it in a different position.
Greg
Thank you, also thank you Bob for the insight, I would like to have it as close to production as possible.
Nice work but Gaines is correct. You are off one or two teeth counter-clockwise. The cap clips are basically 180 degrees front to back.
It will matter on the routing of the spark plug wires. If you don't relocate the distributor, you WILL find that the #1 wire and possibly more will be too short to use all the retaining clips.
#7 & 8 possibly also?
Greg
100% agree  :)...  I have seen the FOMOCO name in the front in some pictures and in the back, intake side on others.  Which is correct from an assembly line perspective?
Quote from: Greg on April 17, 2020, 08:13:59 PM
If you are referring to the trademark on the distributor then it is turned to the back typically from the factory.
Greg
Thank you Bob, that is the way I reinstalled it.  I appreciate the help!
