doug nash (richmond) 5 speed
Started by TLea, October 27, 2025, 09:44:50 AM
Not a crack. It's the parting line between the L & R sides. These are easy to work on Being able the pull a whole side off means you don't need to snake the parts in and out of the top (or side) cover. I circled the reliefs that aid in getting the halves apart.
TA Coupe
This is the crack that I was specifically referencing.
      Roy
If it starts it's streetable.
Overkill is just enough.
Thank you everyone for your added input. Transmission has been sold.
Quote from: TA Coupe on November 04, 2025, 07:36:17 PMThis is the crack that I was specifically referencing.
      Roy
Not a crack. Shadow of the relief machined into the case.
