Correct hood pin and cable orientation
Started by SCJSTU, July 06, 2026, 09:54:06 PM
SCJSTU
Can someone post a picture of the correct direction of hood pins and how the cables are routed over the hood
Thanks, Stuart
1967 Shelby GT350 4-speed #2972
1967 S-Code 4 spd Black/Red
1932 Ford Tudor Hot Rod
1957 F-100 Fridge
1961 Falcon 2 dr wagon
2026 Lotus Emira V-6
1970 Chevy C10 Extended Cab
Sold 69 GT350 convertible 4 speed w a/c
Quote from: SCJSTU on July 06, 2026, 09:54:06 PMCan someone post a picture of the correct direction of hood pins and how the cables are routed over the hood
Thanks, Stuart
First the pin plates are clocked so the rivets are at 12,3,6 9. The pin post is clocked so that the hole is pointed at a 45 degree toward the hood scoop. You adjust the height of the post so that the hole is slightly above the plate  when the hood is fastened down . You should be able to push down one of the rivets on the pin plates with your thumb to expose the pin hole above the plate . You do not want the pin post adjusted down so close to the surface of the plate that the click pin drags across the plate scratching it. The cables are typically secured on the top edge of the grill on early cars and on the forward edge of the pin support bracket on later cars. I hope this helps.
This thread might help...
https://www.saac.com/forum/index.php?topic=11257.msg95183#msg95183
Also here is a promotional photo from back then showing the orientation Bob described...
Quote from: Bob Gaines on July 06, 2026, 10:21:30 PM
Thanks, Stuart
This is why the forum is so great. A question asked and the answer is given by some who has done the research and has the answer
Thank you to all who share their knowledge to the rest of us
SCJSTU
1957 F-100 Fridge
