Unrestored but nice '66 on BaT
Started by 2112, July 12, 2019, 11:08:49 AM
Quote from: Brent on July 17, 2019, 03:12:20 AM
One photo I found interesting is the engine compartment. I've never seen shock towers with holes cut out for, what I'm assuming, is to provide UCA zerk fitting access. Was this a mod done before the 90-degree fittings became available?
Yes its done for access to the owner added zert fittings. Most of the time they are not that pretty.
Plenty of owners don't like messing with the 90 degree angle or crawling under the car. Done this way its allot easier so owners of early Mustangs continue to do this
Bobby Crumpley
I'm impressed that someone went to the trouble of using a hole saw or knockout punch.  Almost everyone that I've seen was done with a torch...
Bobby Crumpley
MCA#20316
www.houstonvaporblasting.com
TOBKOB
QuoteI'm impressed that someone went to the trouble of using a hole saw or knockout punch.  Almost everyone that I've seen was done with a torch...
+1... not very pretty... ::)
TOB
1969 GT350 owned since 1970
sfm5s081
Quote from: TOBKOB on July 17, 2019, 09:02:50 AM
TOB
+1, it's just how they did things back then. I've seen it on many other cars as well
Quote from: gt350hr on July 16, 2019, 11:40:22 AM
  Craig's ( McPaxtonman) comments (IMHO) are valid and the current owner has actual had several addressed if you read carefully. Tune up , valve work , straightened the under ride bars ( or replaced).  Sour grapes? Not Craig. I would bet he has owned close to 100 Shelbys by now including a '65 R Model.
     The information regarding the front attaching point for the leaf springs is very important and the average inspector" probably wouldn't look at that area. In my case I have drag raced 6S477 for 45 years and can tell you right where to look for "stress points" and signs of abuse. Mine certainly has them. In the case of 1124 I would call it "abuse" as there are ( to me) not enough signs of drag racing serious enough to cause those issues.
    1124 none the less remains a nice car , FAR better than many with large amounts of panel replacement. A little more work would improve it more.
I was wondering if mcpaxtonman was Craig. Thanks Randy. Gary
pmustang
I've had more than a few with the holes for greasing up the area. Many are done with god knows what, Looks like a big rat chewed the hole. I have been able to clean up some with a dremel and use a seat nut access plug or similar to cover it up nicely. Have a few in new that are done perfectly with a hole saw of some sort.
Peter
papa scoops
ford did have a service kit for greasing these. it,s what I've always used. no holes. phred
     Mine are still plugged. Guess I don't rack up many miles 1/4 mile at a time LOL. 53 years and still under 87,000 original.
Bigfoot
Looked like a nice piece. Decent price point
RIP KIWI
RIP KIWI
