Steel wheels
Started by Peter L., March 26, 2025, 12:29:20 PM
azdriver
Have had some success with a local steel wheel place. Get them to look for 15 x 6 with the correct hole spacing...
Pat
If youre looking for $100-200 wheels, youre going to need to be very lucky.
There is no hidden secret.
Oem wheels are expensive
65cobra
do mopar wheels fit?  sacrilege...
Mike Shally
Yes Mopar steel wheels fit the 1968 mustangs with disc breaks.
Be careful to check your offset and back spacing.
original owner, 68 Shelby judge, MCA Gold Card Judge, MCACN Shelby Judge
Mustang_Charlie
Quote from: 67 GT350 on May 13, 2025, 09:38:30 PM
Quote from: azdriver on May 13, 2025, 01:10:25 PMIf you can find some the K2/9 wheels are really similar with a slightly larger center hole. Much cheaper than correct K2/8 wheels.
Where do you find them?
Where are you located?   I have a set of 4 Magstars off a mercury (same wheel but uses chrome trim).
I will be going to Carlilse this weekend.
TA Coupe
Don't the Mercury Magstars have a larger "Disc" than the Mustang ones so not the same?
     Roy
If it starts it's streetable.
Overkill is just enough.
Quote from: TA Coupe on June 02, 2025, 07:07:45 PMDon't the Mercury Magstars have a larger "Disc" than the Mustang ones so not the same?
     Roy
Different yes because they are steel rim and aluminum center but they will work fine on a Mustang. They are commonly referred to as Mercury Marauder wheels. There are more 14 inch rim versions out there then 15 inch so there is that.
