Day Two Enhancements to a 2016 GTH
Started by FL SAAC, December 23, 2024, 05:38:24 PM
Open Air Filter
Open air filter on a Whipple supercharger can provide a significant advantage by allowing for maximum airflow to the supercharger, leading to increased horsepower due to the ability to draw in more cool, dense air from the front of the vehicle, maximizing the supercharger's efficiency; however, it's important to consider potential drawbacks like increased noise and potential for debris intake if not properly designed and maintained.
Key advantages of an open air filter on a Whipple:
Increased airflow:
By eliminating restrictions in the air intake system, an open air box allows the supercharger to draw in a larger volume of air, leading to better power delivery.
Cooler air intake:
Open air filters can be positioned to directly access cooler air from the front of the vehicle, improving combustion efficiency.
Improved supercharger performance:
With more air available, the supercharger can operate more efficiently, resulting in increased horsepower.
Potential drawbacks to consider:
Noise increase:
Open air filters often produce a louder intake sound due to the increased air flow.
Debris ingestion:
If not properly designed, an open air filter could potentially draw in dirt and debris, potentially damaging the engine.
Weather sensitivity:
Depending on the design, an open air filter may be more susceptible to water ingestion in wet conditions.
Which to choose?
To be or Not to be?
Open or Closed?
We went with closed
Better air filtration:
A closed box can provide better protection for the air filter from dirt, debris and BUGs.
Here in Floridaland the bugs and pollen when soaked unto the air filter then add our moisture.
Gives you a somewhat cemented seal.
That is why we even put on a Pre Filter on the air filter.
P. S. The yellow is not pollen, it was used to block out the manufacturers name
So what's next after you install all that beautiful "BLING" to the underside of your carriage ?
After these performance suspension upgrades, a proper alignment is crucial to maximize performance and prevent issues like wheel rubbing and uneven tire wear, especially after suspension modifications.
Here's why alignment is so important
A correctly aligned vehicle ensures optimal handling, stability, and tire grip, leading to a more enjoyable and responsive driving experience.
Proper alignment, especially after suspension modifications, is vital for preventing tires from rubbing against the wheel wells or fenders, which can damage tires and other components.
Misalignment can lead to premature and uneven tire wear, so a proper alignment helps ensure your tires last longer and wear evenly.
Improved Handling and Steering with a
correct alignment settings, including camber, caster, and toe, contribute to better steering response, reduced bump steer, and a more predictable handling feel, especially when pushing the limits of your vehicle
Also  subframe alignment kits  ensure proper alignment of suspension and driveline components, especially after suspension modifications or if the subframe is misaligned from the factory.
Like ours was big time.
Installation of adjustable camber plates allow for precise camber adjustments, which can improve handling, reduce understeer, and increase turn-in response.
Tramlining, where a vehicle follows road ruts and lines, can be an issue with wide tires, and proper alignment can help mitigate this.
Here you have the recommended Ford Performance alignments specifications for a GT
Our next topic is staying on track, excuse the pun....
Our recent alignment results are these and it has worked for us, as we have it aligned religiously yearly
Although it is similar but definitely not a like to the F.P. alignment and every other vehicle will also vary due to the alignment and geometry of your own suspension components.
In other words no two cars will ever be the same.
Definitely use a professional alignment shop, it is crucial to ensure proper suspension geometry and maximize performance.
Moving right along on this on going process.
Driveshaft what to do with the stick driveshaft?
Dump it
A one-piece driveshaft in a Whipple 2016 Mustang GT can improve performance by reducing rotating mass, potentially leading to quicker 1/4-mile times, and can be lighter and stronger than the stock two-piece design.
Reduced Rotating Mass:
A one-piece driveshaft weighs less than a two-piece, which means less weight has to be accelerated and decelerated, potentially leading to quicker acceleration and improved handling.
Improved Performance:
The reduced rotating mass can translate to quicker 1/4-mile times and better overall performance, especially when paired with a Whipple supercharger.
Strength and Durability:
The big one Elizabeth!
One-piece driveshafts, especially those made from materials like carbon fiber or high-strength aluminum, can be stronger and more durable than the factory two-piece design, especially when dealing with the increased power output from a Whipple supercharger.
Elimination of Potential Issues:
The two-piece driveshaft can have issues with vibration or noise, which can be eliminated with a one-piece design.
Direct Fit:
Some one-piece driveshafts are designed as direct fits, eliminating the need for adapters or modifications.
WINNA WINNA CHIKUN DINNER !
Only adverse issue is it will set you back $1,200;to 2,000 but thats a small price to pay for reliability and safety
As far as M.P.G. before the power enhancer installed
The stock 5.0-liter Coyote engine, got 15 to 17  M.P.G. in the city.
On the highway our average was between 24 to 26 M.P.G.
After the Whipple install the city M.P.G. (this is driving it like a sane human being) averages between 10 to 14 M.P.G.s
Down 4 +/- gallons
If you affectionately play with the Go Pedal, your M.P.G. will definitely vary.
When we are lively with our Whippled Coyote, the M.P.G. collapse to between 4 to 6 and sometimes even much less.
Our Whippled Coyote M.P.G. averages  20 to 22 M.P.G. on the highway.
Your experience maybe different, but it should be very close to these numbers.
In closing if you bought a supercharger kit and are concerned about gas mileage you are doing it wrong.
You should have used all that cash money to buy a sh☆t econobox to transport you from point A to point B and gotten 50 M.P.G.
As mentioned previously driven like a decent human being in daily traffic 12.6 MPG
But on a recent trip to the west coast again driving like a decent human being,  cruise control on.
Not exceeding the posted speed limit, actually 69 MPH all the way
I would say not bad at all
This is what happens when the GO PEDAL gets applied frequently
2.1 MPG or possibly much less...that's a  hungry motor
So now you have experienced
the GOOD
the BAD
and the UGLY
But boy is this a fun C.S.M. sized machine or what?
Second to none !
So what exhaust to use?
Now that's a great question citizen.
There are so many choices out there, from mild to wild.
You can have a full months discussion and come to no conclusions what so ever.
Probably harder than choosing a new Pope.
Lucky for us our "Legendary Cult Car" or The 2016 GTH came equipped with the Ford Performance exhaust made by Borla .
It is a stainless steel sport 2-1/2" cat-back exhaust system with 4" chrome exhaust tips.
Manufactured out of T-304 Stainless Steel, this 2-1/2" cat-back exhaust system will give you an aggressive muscle car sound.
 The Ford Racing by Borla Cat-Back exhaust system utilizes an integral X-pipe that bolts directly to your factory catalytic converters, keeping your Mustang 100% emission compliant.
And the tuned stainless steel mufflers with 4" chrome-plated stainless steel tips not only sound great but look amazing as well.
Features and Benefits:
- Full Stainless Steel Construction
- Chrome plated 4" Exhaust Tips
- Ford Racing Logo Embossed on each Exhaust Tip
- 2-1/2" Mandrel Bent Piping
- Straight Through Design with No Drone
- 30 lbs Lighter Than the Factory Cat-back System
- Utilizes an Integral X-Pipe
- Reuses Stock Exhaust Hangers and Mounts
This is a factory approved high performance alternative.
People have asked many times "what exhaust did we install on our car"
The reply is always...stock...the car is 100% stock...
A little item that makes a big difference
A fuel pressure regulator is essential for any Whippled Mustang to ensure proper fuel delivery to the injectors, especially with the increased fuel demand from the supercharger.
 The regulator maintains a consistent fuel pressure, allowing the injectors to function correctly and deliver the precise amount of fuel needed for optimal engine performance.
Consistent Fuel Pressure: The regulator ensures a constant and adequate fuel pressure in the fuel rail, even under high boost conditions.
Optimal Air-Fuel Ratio: By maintaining consistent pressure, the regulator ensures the fuel injectors receive the correct amount of fuel, leading to an optimal air-fuel ratio.
Prevents Misfires and Stalling: Without sufficient fuel pressure, the engine can starve for fuel, leading to issues like misfires, rough idling, and even stalling.
Supports Increased Fuel Demands:
A Whipple supercharger significantly increases airflow into the engine, requiring a proportional increase in fuel. The fuel pressure regulator ensures the fuel system can handle this increased demand, preventing fuel starvation during acceleration or high-load situations.
We ultimately went with this kit the Mustang GT Level 2 Return Style Fuel System (Whipple / Edelbrock Supercharger)
Why
this system as opposed to others that use a factory style fuel hat and pump setup?
 This system has much more capability than other kits on the market and as mentioned can easily be upgraded to a triple pump setup.
Others systems are stuck using only two inferior fuel pumps where this system has the option to use up to three of the top-notch pump offerings from Walbro.
That's why
