69 Shelby gas cap
Started by kasearch@ix.netcom.com, May 03, 2022, 01:49:39 PM
The G40A has a check valve in it that lets air in the tank as fuel is depleted. It does not let fuel or fuel fumes out.
crossboss
FWIW,
My old 1970 GT-500 had a non-vented cap. Yes, it was a California car.
Past owned:
1968 GT-350
1970 GT-500 #3129 Grabber Orange.
Current projects:
1969 Mustang Fastback/FOX chassis, 5 speed, 4 wheel discs, with a modern Can-Am 494 Kaase heads, intake with a 1425 cfm  Autolite Inline carb,  Trans-Am style
1968 Olds 442 W-30
1970 AMX 390 BBB 4 speed.
Right, the California and Arizona cars had an evaporative emissions charcoal cannister that is the vent for the tank, so a different gas cap is used for those cars. It doesn't need a vent if the system is installed and working properly.
Quote from: crossboss on May 06, 2022, 04:49:08 PM
FWIW,
Quote from: Royce Peterson on May 06, 2022, 06:24:46 PM
FWIW,
Those different non vented caps used on the evaporative emission equipped cars fit a special necked down filler tube which makes it necessary for the the cap to be much smaller then the typical stock cap.
Royce didnt know az had same fuel evap law as cali where did u get that info as didnt it say on invoice cali evap option or was it by dso?
Ed,
Arizona adopted the California emissions rules in about 1964 so anything California did they made the same. Arizona adopted Thermactor at the same time as California, etc. Probably because Phoenix and LA both had serious air pollution from car exhausts and fumes.
crossboss
Also, wasn't there a re-call concerning the gas caps causing fires from the fumes and the center exhausts?
Past owned:
1968 GT-350
Current projects:
1968 Olds 442 W-30
Quote from: crossboss on May 07, 2022, 11:45:56 AM
Yes and for cars that returned for that they got a non-vented cap and a vent added to the factory filler neck as shown in past threads on the subject
Quote from: J_Speegle on May 07, 2022, 01:34:18 PM
A slight addition in that besides the added tube vent the dealer ether replaced the stock cap with a non vented cap or made a revision to the stock cap that rendered it non venting as per factory recall instructions.
