finished reproducing some Paxton gauges
Started by crxnug, January 21, 2018, 10:41:13 AM
   Phil,
      The most "I" ever made was 13 psi back in the '70's. I had all kinds of problems keeping the drive elements from failing. A bunch of extra heat was generated and I was cooking the oil which led to ball bearing failure until I went to B&M trick shift and added and a "snake oil" called Alaskan brand engine oil coolant. The double spring pressure plate helped to make the boost along with a special impeller and small blower pulley. That combination was able to "live" for about 6 months of weekly drag racing and very limited street use. Not worth the effort these days. Despite the suggestions of Vince granetelli to go to a "direct oiling" ( engine oil pressure fed) I stuck to the standard self contained ATF oiling.
zray
a combination of the synthetic B&M Trick Shift and a fluid cooler via the special dipstick,  will enable the ball drive Paxton's to be indefinitely long-lived, regardless of the output with the VR-4 impeller or other enhancements.
I put 85,000 miles on my last Paxton equipped GT-350. At the end of which, there was no measurable wear on the blower unit
Z
   There is a very specialized "electronic vapor deposition" coating that could be applied to the drive elements and eliminate failure. This coating , known in the trades as "DLC" ( diamond like carbon) has been used on wrist pins , solid lifters , valves , rocker arm shafts , and other "problem areas". It leaves a black coating on steel that is virtually wear proof with minimal lubrication. If I were still running a Paxton , I would do this modification.
zray
Quote from: gt350hr on October 19, 2018, 11:54:51 AM
^^^^^^^^. +1
Z
