On the hook, again
Started by Bill, August 22, 2020, 07:20:34 PM
1109RWHP
If that was the case you would be able to two foot it and keep it running.
rhjanes
Quote from: 1109RWHP on August 23, 2020, 11:18:27 PM
If that was a response to my RPM post, yes, true.  I'm not seeing in the original post if "two footing it" was tried.  I was able to do that on my 302.  I also put up with it for a while before I decided to see about a better solution.  Since I was "prepared" for it to stumble, I would also be ready to slap it into neutral and try and goose it before it stalled in traffic.  Old cars......  :o
Quote from: rhjanes on August 24, 2020, 09:37:41 AM
Did not work, lucky to get moving temporary for a few residential side streets, idling around in first gear, down hill worked until I stopped...Then the car died again.
HOW TO IDENTIFY A FORUM TROLL
1109RWHP
Sounds like a converter issue. I had some do that when I worked at  Masano's.
This also has similar symptoms of the idle air bleeds being blocked. It doesn't take much to do that.
Mine clogged up on the GW Bridge on a Sunday. The car wouldn't idle but would run once on the main circuit.
You can't tell necessarily by just looking at them. They need to be cleaned out with a pin vise and compressed air.
