What did you do to your '67 today?
Started by rmarble57, July 18, 2020, 04:27:34 PM
BeaterGT500
I picked up my rebuilt 428 long block today.  After looking at it for 19 years, finally got it redone.  Went with a nice roller cam setup, the stock dual quad intake, and scored a rare SSS finned COBRA oil pan to boot.
557
Quote from: BeaterGT500 on December 24, 2020, 01:14:04 AM
Are you under the misconception that the finned aluminum big block Cobra oil pan was a original Shelby item? Branda has been selling the creation they cam up with (not Shelby) for 40 years. It is still available through Branda . You may think it is cool which is no harm no foul but it is not rare . http://www.cobranda.com/bigblcooilpa.html
68krrrr
Trying to figure out WTF I'm supposed to do with these metal tabs that I got from the DMV today to go with my recommissioned California black license plate ,I picked the plate up from a vendor on eBay recently and it starts with a U which is correct for a 1967 California plate .It also came with a 67 tag on it ,when  I took it to the DMV they told me to keep the sticker on it,which I kind of like any way but don't want these metal tabs hanging off my plate.
Current
1967 GT500 #1724
Nightmist Blue /Parchment
2005 Ford Gt Midnight blue
1934 Ford Chopped & channeled
Previously owned
1968 GT/CS
"Fly low & avoid the radar"
Thanks Adam
557
Just put the sticker over the old ones.That's what I did when I got my original plates reassigned to my car about 10 years ago(it had dropped off the grid after a long nap)btw that tab thing must be a new development,dmv didn't give me one :'(.If you like the 67 sticker you could try and work it off carefully with a razor blade(and maybe heat?)for "future reference "I suppose.Good luck.
greekz
I ran recommissioned black plates on my '67 for about 3 years and did not use the metal tabs.  I carefully removed the 1967 sticker and placed the correct month/year stickers on the plates as I do with my 1966, that has its original plates.  I do not think the registration card indicates recommissioned plates.  Never had a problem, also never was stopped by police.  Friends of mine have done the same.  I do not think there is anyway for law enforcement to tell the difference.  It is up to you.
Greek
SFM 6S1134  '67 GT-350 #2339
DGSOH
Though small I FINALLY got the correct style ammeter terminal block installed. It's one of those things that's been bugging me for years... thanks JD! I feel much better now.
Having had some experience with wiring on things that move, it's curious why SA chose the block they did and installed it the way they did. Those guards typically act as keepers for the conductors so in my view it's the wrong part installed incorrectly. But what do I know.
At what point does a hobby cross the line into mental illness (rhetorical)? I think I must be there.
Hmmm, I see in the photo that solenoid could use a little more cleaning, and there's some dust just below it, and...
Happy Holidays all!
67gt500
Quote from: 68krrrr on December 24, 2020, 01:27:27 PM
Cut a fridge magnet to the correct shape and stick the new sticker to it.. Place it over the 67 sticker..
Quote from: DGSOH on December 24, 2020, 03:36:50 PM
Happy Holidays all!
Do you have the amber circuit board looking material insulator underneath the early terminal block like was done originally?I can't tell from the picture angle.
DGSOH
Quote from: Bob Gaines on December 24, 2020, 06:46:38 PM
lol Yes I do. I had a feeling you might bring that up. In fact it's the insulator I was specifically thanking JD for.
And for the benefit of others, there's a really good reason the insulator is there - don't install one of these without it would be my recommendation.
Thanks Bob! And I hope you and yours have a great holiday.
68krrrr
Quote from: DGSOH on December 24, 2020, 06:55:16 PM
Can you let us know where you sourced both of these parts thanks
Current
1967 GT500 #1724
Previously owned
1968 GT/CS
Thanks Adam
68krrrr
Quote from: 67gt500 on December 24, 2020, 04:26:23 PM
Huh might try that thanks
Current
1967 GT500 #1724
Previously owned
1968 GT/CS
Thanks Adam
Quote from: 68krrrr on December 25, 2020, 12:16:07 AM
Your later car does not use those early car parts if that is what you are thinking.
68krrrr
Current
1967 GT500 #1724
Previously owned
1968 GT/CS
Thanks Adam
BeaterGT500
I spent enough time to kill three rechargeable batteries on my Makita cordless drill with a brass wire brush on it, cleaning surface rust off cast iron parts for refinishing.  Bellhousing, strut rods, spindles, coil springs, motor mounts, steering shaft, clutch fork.  Fun times in the 40 degree shop.
