Marti Auto Works Strikes Again.....Maybe
Started by greekz, June 24, 2020, 03:47:10 PM
Heard Bangladesh is lovely this time of year..... :o
greekz
Here is the outcome.
I stopped by NPD to show them the hose was too large for 5/16" fuel line.  Told the salesperson I installed a short section and it leaked.  He promptly measured the hose I.D and said "it is 5/16" so nothing is wrong.  He went and got another hose kit and measured the hose I.D. and said "it is 5/16".
I said, " here is a piece of hose I bought for 5/16' tubing and it fits perfectly."  He measured my piece of hose and said,"it is a 1/4" I.D., it is miss marked.  No matter how hard I tried to convince him that the Marti hose was too big he would not relent.  I told him this hose is useless to me for may application I want to return it.  Since I had cut off a short section, he would not take it back.  Could be my last purchase from NPD.
My understanding has been a hose for a specific size tube has a smaller I.D. than the tube so it can seal better.  Maybe I am wrong, but logic tells me something different.
SFM 6S1134  '67 GT-350 #2339
69mach351w
Quote from: Chris Thauberger on June 25, 2020, 05:59:12 PM
Quote from: 69mach351w on June 25, 2020, 03:16:32 PM
Quote from: Chris Thauberger on June 25, 2020, 09:48:23 AM
Quote from: QuickSilverShelby on June 25, 2020, 09:38:33 AM
So if I order a set of these and they happen to come in Metric will they fit my car perfectly since I'm in Canada?  :D
QSS
Well technically speaking they are metric so they will fit if you live anywhere except Federated States of Micronesia, Liberia, Marshall Islands, Myanmar, Palau, Samoa, and the United States.
Theses are the only countries that do not use the metric system  (sort of)  ;)
You missed Bangledesh  ;D
Bangladesh Adopted the metric system July 1, 1982
I knew that, I was just testing you ::)  ;D
Quote from: greekz on June 25, 2020, 07:19:19 PM
It is the metric scenario I suspected. You need to talk to Scott. He is a concerned Mustang car guy ,MCA concours judge and best of all part of the NPD hierarchy . I will try and find contact info for him.
cbrown
#19
jswoody
Quote from: Bob Gaines on June 25, 2020, 11:21:43 AM
Quote from: The Going Thing on June 25, 2020, 12:32:22 AM
Bob:
The quads and fuel log had stainless crimps in '82 when I purchased the car. As for the fuel line I went to the 3/8" feed tank to pump down the outside of the rocker. So all clamps at the log and the main feed to the pump should be Olive pinch clamps?
5/16 fuel log hose used the crimp clamps. Stainless is typically too brittle and expensive to be used in crimp clamps so they are typically a bright zinc plated steel . Just the fuel line past the sender to the pump used the spring clamps. The olive identification color is for 5/16. If using 3/8 line on a 67 but wanted the historic look you could paint the silver color 3/8 spring clamps olive drab so as to not draw attention to the larger 68 model line on a 67.That is if you cared to disguise it.
Sorry to back track to this, however I need a little clarification.  I thought 1967 used all crimp clamps.   Is this the connection between the fuel tank sender and undercarriage fuel line?
Bob this is not correct - crimp clamps on rubber section at the sender?
Also line to the carb - spring clamps Olive color/finish?
greekz
Quote from: cbrown on June 26, 2020, 12:55:37 AM
Shalseth@npdlink.com.   ;)
Chris
Thanks for the information.  I will send him an email.
Quote from: JD on June 26, 2020, 08:20:43 AM
JD,crimp clamp on rubber section at sender is correct. GT350 or GT500. The assemblyline manual confirms although small illustration. Crimp clamp is the same type as your picture. I never addressed the smallblock fuel pump to carb given the GT500 Going Thing posed question at the time. On the GT350 it should be spring clamp for a GT350 however in that case for what ever reason I do not believe olive drab like the other spring clamps on th fuel line. I have found those to be a dark black oxide. Like what is found in fuel filter kits. I don't know if that is where they came from in the case of the GT350 just that they coincidentally look the same.
JD, I amended my earlier post to make it more clear.
Bob - THANKS for the clarification.
I think that since the original poster (greekz) was asking about '67 GT350 at the carb some of us were looking that way not so much the GT500 direction.
Quote from: JD on June 26, 2020, 12:13:00 PM
Not the first time a thread has taken a RIGHT TURN . :o
Bossbill
The crimp clamps with the indentation are later reproductions that are visually incorrect for Concours.
The original clamps do not have the indentation as far as I know...
70 B302   6/6/70  0T02G160xxx
Quote from: Bossbill on June 26, 2020, 12:56:54 PM
+1 . The clamps with the indents are not the type used on the assemblyine. The indents are not reproduction but the evolution of the design. The later clamps incorporate the indent as a way to strengthen the crimp part of the clamp. It is incorported into the design to help keep it from collapsing when crimped.
Bob, so the later dimpled version is OK for Division II concours?
(and yes we do seem to veer around on topics don't we ;-) )
