Daytona pinion support.
Started by TLea, November 02, 2026, 06:48:15 PM
    If your concerned for the "date code" you didn't mention it?   :)
    Also, I've noticed that there are different executions in that some of these will distinctly present a machined surface about the retaining bolt (5 pcs.) circumference face, whereas others provide no evidence of this machining operation at all?  Any ideas out there on the "when & why's"?    ???
Scode67FB
All of the non-machined versions that I've seen have been from trucks 1971 and later. There was also a later version with the cast-in pinion snubber.
    Yeah, I have a few those with the "cast-in pinion snubber", "hooded" or "guarded" version also, which seem to bare the "D2OW-4668-C" casting number, but I didn't bring up that one as I just 'assumed' it wouldn't be relevant here.  :)
    But, how sure are you on the thought that the un-machined examples would be of "later" production and particularly out of "trucks" (originally); and the '85 F150 H.O. unit doesn't count as it also presents other differences which side-line it here.  This as I don't recall ever finding one there, that as being obviously original anyway; although I'll also be the first to say "I ain't seen it all", for sure, and to reiterate the saying of: "never say never"?  But also, based on my 'bad' memory, I had the impression that those un-machined units might have actually been "earlier" examples in production, but I very well may be wrong, hence my inquiry?  :-\
    To bad the "casting date codes" couldn't provide us some guidance, but it seems Ford chose to not include a year in the casting identifier, only month and day, so don't think rummaging through my "stuff" would really help greatly.  :(
Quote from: pbf777 on November 03, 2026, 11:25:48 AMIf your concerned for the "date code" you didn't mention it?
In a perfect world I would like one that would work with a 8D case but I'm open. Must be fully machined and no D2s
Pcunder
I'll send you a DM but, I've got the one that came assembled with that 8D non-marked N carrier I sold you...
Scode67FB
All of the non-machined ones that I've seen carried a "D1OW" number on them.
