Air cleaner hose to breather cap
Started by SCJSTU, July 29, 2026, 06:58:37 AM
SCJSTU
I've seen couple different air cleaners on a 67 GT350
Is this setup correct for a June built SAI car?
1967 S-Code 4 spd Black/Red
1932 Ford Tudor Hot Rod
1957 F-100 Fridge
1961 Falcon 2 dr wagon
2026 Lotus Emira V-6
1970 Chevy C10 Extended Cab
Sold 69 GT350 convertible 4 speed w a/c
Road Reptile
Hi SCJSTU,
The picture you posted is a typical closed crankcase type. If your car is a 200 series and sold new outside of California (thermactors were suggested to be sold within that state) Very few HIPO 289 engines were equipped with them. And they are difficult to find correct parts for.
They (thermactor equipped) also used a closed crankcase type as pictured.
R.R.
greekz
My car is a May 23, build and it has an open system.  If you have a zero (67200 or 67210) as your third numeral, you should have a cap like the one pictured with AUTOLITE stamped on it.
SFM 6S1134
'67 GT-350 #2339
'65 Fairlane Station Wagon
2002 T-Bird (since new)
'25 Explorer ST
Quote from: SCJSTU on July 29, 2026, 06:58:37 AMI've seen couple different air cleaners on a 67 GT350
That setup is for a thermactor equipped 67 GT350. The typical non thermactor is like picture in reply #2. The air cleaner base would not have the large nipple for a hose. It typically had a small 1/8 nipple that was capped off.
Road Reptile
Hi all,
Just to verify things a bit more. The picture shown with a cap without a hose is known as "open"
And was not intended for use on California cars after the beginning of 1967. We see this on many
Invoices so I would suggest getting documents from Dave Matthews to show where it was sold new,and if there is any doubt as to cost,get a Deluxe Marti report. They were under $7.00 I think.
Greeks car was part of the train derailment and was intended to be sold originally East of California, which would explain why it is an "open" type.
R.R.
Quote from: Road Reptile on July 29, 2026, 07:34:00 PMHi all,
R.R.
Regardless of where the car was sold new the Shelby engine code in the Shelby VIN will determine if the car was built with thermactor or not. 202 for 4 speed and thermactor, 203 with thermactor and air. 212 is auto and thermactor or 213 for automatic and thermactor with air.
SCJSTU
My car is 67200 series
Thanks fellas
1957 F-100 Fridge
