Shelby 289/302 ram box/mini-plenum
Started by Pcunder, August 03, 2026, 06:26:02 PM
#15
Quote from: Pcunder on August 07, 2026, 09:51:44 AMThose NOS 4100s are only 480cfm but not sure if that's close enuf...as they say.
    I'd just run 'em!  Remember, whatever they might flow is multiplied by a factor of two, which works out to be a fair sum of carburetion for something under an 8.200" deck height block.  ;)
QuoteWhile collecting Autolites, I wan across a device that "converts" a 4100 to mechanical 2ndaries...No, not a double pumper but wonder if that's close enuf or makes it better... Hmmmm
    I'd probably say that that would not be the best idea; as with the rather large plenum area that that manifold presents, this generally dictates the need for a lot of "pump-shot" to overcome fuel delivery deficiencies in transitional throttle instances, and the 4100's won't be able to provide this.  So if not for an all-out race effort and your gonna try 'em, leave 'em as vacuum operation.  :)
     P.S.  If your not gonna run 'em, and you don't want 'em, I'll give ya' fifty bucks for 'em!   ::)
JohnSlack
Quote from: kram350 on August 06, 2026, 08:54:45 PMPcunder, Made my own gaskets, just scissors and a hole punch. Just a heads up and probably not really necessary but some safety wire on the interior manifold bolts might be wise. A loose bolt could ruin your day.
I would ABSOLUTELY suggest safety wire, I had one of the center plenum bolts come loose on a Mini-Plenum. The bolt made it to the #4 exhaust valve.
John
