VIN # stampings
Started by Wedgeman, February 28, 2019, 10:57:38 AM
oldcanuck
Quote from: Skidado on March 06, 2019, 02:34:26 PM
Quote from: Bob Gaines on March 06, 2019, 11:25:31 AM
Quote from: Skidado on March 06, 2019, 11:21:37 AM
Quote from: oldcanuck on March 05, 2019, 05:22:19 PM
Quote from: Skidado on March 05, 2019, 03:54:04 PM
My trans has only the last four digits of the ford VIN not the whole number. David
That's one of the reasons I asked as well..... mine only has 4 as well....?
...and no VIN on the block. I wonder if there is a correlation between these two things?
David
If big block no reason to think so . If smallblock maybe.
Yes - smallblock #2751
My s/n is very close to this, and also have the last 4 on the trans, and nothing on the block.
Bob
Philadelphia, TN
Vernon Estes
Quote from: oldcanuck on March 06, 2019, 07:40:13 PM
David
#3069, in survivor condition with original paint 3 owner car which included the original owner owning the vehicle twice up into 2012....abbreviated trans VIN, nothing on block. Casting date on block, assembly date on block, and hipo heads all dated perfectly to each other and to the build date of the car. Engine had clearly never been pulled or rebuilt.
And Dave told me before I went to inspect it that there would most likely not be a VIN on the block even if it was the original block.  A corroboration of the evidence presented on that car left no doubt in my mind whatsoever that it was the original engine to the car.
I'll echo what others have said previously though. Dave M. seems to have it pretty well figured which cars should and shouldn't have block VINs..it isnt something that extends to 65 or 66 and it isn't something that applies to all 67 GT350s. Just throwing that out there because discussions like this always seem to lead to an onslaught of Hemmings ads for 67 GT350s without their original engines claiming "not all 67 GT350s had VIN stamps" when it clearly doesnt apply to the specific car for sale in the ad.
Kind regards,
Vern
Junk dealer and the oldest young guy you will ever know.
Vernon Estes
to add to the discussion, 3167 was a survivor condition GT500...abbreviated VIN on trans.
Kind regards,
Vern
557
557 a gt500 has the full vin on the tranny.
Skidado
If there were an exact correlation between the abbreviated VIN on the trans, and no VIN on the block, then 'The Knowledgeable' would know a bit more about what to expect when they inspect a vehicle.
Is this correlation known?  Can it be revealed?
For clarity - we are talking specifically about small block cars here; no doubt there is a discussion to be had about big blocks.
David
Quote from: Skidado on March 09, 2019, 09:04:17 AM
David
Re read reply #27. Unless and until all engines can be examined a educated guess is the best that can be expected. Dave M is best equipped to make the the most educated guess at this time.
SFM5S159
I was able to get a look at the engine for my GT500, which had a completion date at Ford in early Jan, '67. (Jan 9th)  What is a reasonable range of date codes for the engine to be a likely match for the car?
I was unable to see a date code on the block as its sitting on the floor and not easy to get to...I found an casting date of August on the cylinder heads.  Both heads share the same August date.
Would it be plausible for a an early Jan completion at Ford to have August cylinder heads?
I know this thread is a little old but it took me a while to get a look at some of the date codes.  It is the correct C6ME-A block.  Just haven't seen the date code yet on the block.
Mike C
'65 GT350, '67 GT500, '65 289 Cobra
Quote from: SFM5S159 on March 27, 2019, 04:17:31 PM
Mike C
Possible Yes, but a very not typical.
Have also found engine blocks with much earlier heads.  (But these were not BB engines)
Maybe these will help out in your search. Best to collect as much data as possible to see what kind of picture the whole puzzle paints before trying to determine possible answers or conclusions ;)
Quote from: J_Speegle on March 27, 2019, 04:49:10 PM
Just to add to Jeffs picture post for clarification is that in his first picture is the block casting date and the second picture is where the engine plant metal stamped the block when the engine was assembled. That is the difference between the two different dates.
SCJSTU
Good stuff need to bring
 It back up so easy for folks to find
1967 S-Code 4 spd Black/Red
1932 Ford Tudor Hot Rod
1957 F-100 Fridge
1961 Falcon 2 dr wagon
2026 Lotus Emira V-6
1970 Chevy C10 Extended Cab
Sold 69 GT350 convertible 4 speed w a/c
