GT500 oil filter adaptor
Started by csheff, June 11, 2026, 11:50:24 AM
csheff
What are the correct pieces needed on the top for the line going to the gaugees? Are they just plain brass connectors? Is there a kit u can get anywhere?
Quote from: csheff on June 11, 2026, 11:50:24 AMWhat are the correct pieces needed on the top for the line going to the gaugees? Are they just plain brass connectors? Is there a kit u can get anywhere?
The fittings are steel plated zinc silver not brass. The fittings consists typically of 3 pieces. You can not get a kit just anywhere. As an alternative you could plate the brass fittings zinc silver to mimic what the steel fitting looks like.
csheff
