289 HiPo 5-Bolt Engine and Transmission For Sale
Started by drboss, February 24, 2026, 07:58:35 AM
drboss
    I have the following HiPo parts for sale from a project that I decided not to complete:
    • 5-bolt Engine block with caps, crank, heads, rods, and cam $5500 - C4OE-6015F casting date 4F4. VIN is 5R07K100254 which decodes to a very early San Jose K-code coupe. There is one broken ear that needs repair. The bores appear to be standard. Crankshaft appears to be original and complete with hatchet. Heads have all HiPo marking with 4D24 casting dates. Camshaft is from DeLong racing and missing two lifters.
    • Carter X3732S Fuel Pump - $350
    • Rebuilt water pump - $475 C5OE rebuilt with new impeller. Painted incorrectly blue.
    • Bellhousing and spacer plate - $260
    • HEH-S Top Loader Transmission - $1750 Partial VIN 5F07K19153?
    • Gear shifter and assembly - $450
    • Valve Cover Extenders - $100
    • Distributor - $250 C5OF-12127-E "5L8" date code. Modified with two plugs.
All of the parts can be seen here: https://photos.app.goo.gl/Eg7eXrAsNuBpuxrL7
I would prefer not to ship the heavy parts. These can be picked up pickup near Hagerstown, MD. I could possibly deliver to Spring Carlisle or the 2026 Ford Nationals.
Thanks!
