1969 Shelby Parts - NOS and Used for Sale
Started by nightmist67, April 08, 2025, 02:18:50 PM
nightmist67
Original Used 1969 Jack and Handle:  $180
Original Used HVAC Vacuum Actuator Motors w/Arms (3 available):  $40 each
NOS YK-22 C9ZZ-19B888-A A/C Vacuum Selector Mode Switch Valve Assembly:  $35
NOS C8SZ-13B064 Tilt Column Vacuum Check Valve:  $75
NOS WG-3 C9AZ-17664-A Windshield Washer Motor Kit:  $50
NOS FC-535 Non-Vented Gas Cap:  $125
NOS C6OZ-2A790-A Parking Brake Cable Clevis:  $15
NOS C9ZZ-3D536-A Tilt Steering Release Valve Assembly:  $130
NOS C9OZ-16228-A Cobra Emblem (2 available):  $50 each
Original Used Space Saver Inflator Bottle:  $150 SOLD
NOS Center Console Ashtray:  $200  SOLD
Original Used Center Blend A/C Vent Duct w/Vacuum Actuator Motor (Date Coded H8M17B):  $75
All prices do not include shipping costs, which will be determined at time of sale.
Is the NOS FC-535 Non-Vented Gas Cap the smaller diameter version for the California emission smaller diameter gas filler neck?
HKAUTOMOTIVE
Interested in the center console ash tray.  Can you send contact info?
Mike H
nightmist67
The OD of the non-vented gas cap is 2 1/4".  The OD of the inner ring of the gas cap is 1 3/8".
Quote from: nightmist67 on April 11, 2025, 10:22:51 AMThe OD of the non-vented gas cap is 2 1/4".  The OD of the inner ring of the gas cap is 1 3/8".
That gas cap is for the CA only evaporative system gas cap that has a smaller filler neck opening then a typical 69/70 Shelby. It will not fit a typical Shelby only the CA system equipped Shelby
HKAUTOMOTIVE
STILL INTERESTED IN THE ASH TRAY IF AVAILABLE.  I CAN BE REACHED AT 704-791-O536.
aj
PM sent.  Interested in the jack and handle.
Survivor
Are the Cobra emblems correct for a convertible.
TA Coupe
Maybe he can point out which emblems he has by looking at this picture of some of mine and let you know which ones he has.
      Roy
If it starts it's streetable.
Overkill is just enough.
Survivor
Hi: still interested in the emblems if you could lmk if they are correct for a vert.  Thx.
