1967 GT500 transmission identification help
Started by 1968GT500CS, May 06, 2024, 06:54:34 AM
1968GT500CS
Hello 1967 experts
Are 4 speeds, if from genuine 67 Shelby 500 marked in some way identified?
Vin? Etc
For that matter, the block is Scratched A, and that is date ranged prior to build date...correct?
Crank is what part number?
RUG-S is correct?
Thank you
S7MS427
Yes, RUG-S is correct. The last six characters (or is it four?) of the Ford VIN should be stamped on the boss of the main case just in front of the extension housing.
Roy Simkins
1966 G.T.350H SFM6S817
1967 G.T.500 67400F7A03040
Quote from: S7MS427 on May 06, 2024, 07:13:16 AMYes, RUG-S is correct. The last six characters (or is it four?) of the Ford VIN should be stamped on the boss of the main case just in front of the extension housing.
I have seen almost entire vin stamped before but not seen less then the last 4 .
