Early 64 NOS HiPo Timing Cover and Edelbrock Waterpump also new
Started by SFM5S000, February 05, 2023, 10:30:08 PM
SFM5S000
I think I can get away with this. This timing cover came to me as NOS never been mounted, NO WITNESS MARKS on the crankshaft seal hole/area. bolt head surfaces, water passage surfaces etc. BUT, I did have my machinist plug the big Oil fill/breather hole. I also had the little breather passage notch welded and milled closed. He also milled the waterpump surface flat as with a new EdelBrock waterpump (#2241?). It also comes with a new but painted dipstick tube I got from Jim Cowles (RIP).
I was going to use this on my engine build but the new M-6010 BOSS302 block takes a different timing cover!!! Ack!
So, here it is. Still no crank seal installed.
The modifications to the timing cover can be reversed. Remove the plug and add a notch to the mounting surface.
What you see is what you get.
$500.00 plus UPS shipping whatever that is to your zip code.
Cheers,
~Earl J
SFM5S000
SFM5S000
