1969 GT350 same as 69 Boss disc brake rotors or suggestions
Started by CHGOHR, September 28, 2021, 01:28:39 PM
CHGOHR
Thanks in advance I am looking for front disc brake rotors for my 69 GT350. They are the 69 Boss 302 ones . Any help or suggestions are welcome. Ian cell 773 551 5075
68 GT500
69 GT350
72 Pantera pre L MSO
66 Tiger
65 K code (original owner Dad's)
Quote from: CHGOHR on September 28, 2021, 01:28:39 PM
Those rotors have been obsolete for decades. The replacements that Branda and NPD sold are now all out of stock with no prospect of another run I have been told. You might try ether and double check. I would think that if you could find a set like Branda and NPD sold (500.00pr) and found them at any less then twice what they sold them for it would be a deal. Of course you could always change out the spindle to the smaller 68/69 spindle  like so many did for the past 40 years when the proper Boss 302 type rotors could not be sourced. You could also change out to a 1970 Mustang spindle . Ether spindle has a one piece rotor alternative available at local auto parts stores.  Sadly the two piece rotors like the factory for 68-73 have not been obsolete for about a decade leaving only the one piece rotor as a alternative now.  If you can find a equally hard to find rotor hat (machined disc portion)for 68-73 you could press that on to your Boss 302 hub . That is if you even have the hub from the car. Many have been changed out as I mentioned long ago. I hope this helps give a perspective. Keep us posted on what you find out. Best of luck with your search.
CHGOHR
I can re use my original hubs as they are good. So does anyone anywhere have a rotor that's usable? Yes I have checked with Branda and NPD already. Thanks.
68 GT500
69 GT350
66 Tiger
CHGOHR
The other thought is would wildwood rotors fit my original hubs?
68 GT500
69 GT350
66 Tiger
