Headlight Bucket Plastic Grommet
Started by Corey Bowcutt, March 19, 2021, 09:58:26 AM
Corey Bowcutt
One of my headlight buckets came with a plastic grommet in the hole to protect the wire from the metal edge.  The wire harness on this side also has a rubber grommet as part of the wire harness that would presumably do the same thing,  The other bucket does not have either grommet.  Is there supposed to be a plastic grommet, rubber grommet, both or none?  If it is supposed to have the plastic grommet I have not been able to source any, does anyone know if they are available anywhere?
Thank you,
Corey
Corey Bowcutt
Thank you Pete.  I sent you an email.
Corey
Corey Bowcutt
So is the rubber grommet shown in attached pictures correct?  If not what does the correct grommet look like?
