SFM5s444 restoration is continuing
Started by doublemyv, August 15, 2018, 02:14:39 AM
doublemyv
Well, it's almost Thanksgiving and I have read every forum tip, magazine article, and youtube video on glass installs and I am about ready to tackle this project.  I have 2 tubes of sealer, tools, the gasket has been relaxing on the glass for a couple of weeks, so the only thing left is to tape off the area, and get started.  We'll see how it goes with the rear glass, and hope for the best.
GT350Lad
Good luck! And lets us know how it goes
Cheers
5S274
6S373
6S1276
doublemyv
The rear glass is now installed.  My wife and I spent the day ( just about 8 hours total ) getting the windshield caulking in the gasket groove for the glass, then fitting the gasket to the glass.  What a chore, and quite possibly the messiest job on a car I have ever done.  The caulking/sealer gets on everything, and the stringy trails of the stuff goes far beyond the intended area.  Wow.  Anyway, we then put the caulking/sealer in the outer groove that goes on the pinchweld.  Then we applied the same caulking/sealer to the pinchweld around the entire opening, with a solid bead on the flat pinchweld at about the bottom level of the trim clips.    A light coat of Vaseline petroleum jelly on the lip of the gasket that the string pulls inside the pinchweld, and using the 2 suction cups in the photos, lifted the glass into position in the opening.  With a bit of fiddling by pushing and pulling on the suction cup handles, we got it centered, pulled the string ( actually 14 gauge electrical wire )  and between the wire's slick insulation, and the Vaseline in the inner gasket lip, the process went remarkably smooth getting the lip inside the pinchweld all around the window opening.  Even the 90 degree upper corners were pretty easy.  After double and triple checking the entire perimeter, I then used the caulking gun to put a thick bead of caulk/sealer all around the exterior of the gasket where it meets the trim clips to fill the void from the gasket to the wall of the window opening.  It took a full 2 tubes of caulk/sealer to finish the job.  Then, some initial cleanup and fitting of the stainless trim, and using the palm of my hand, all the clips seated the trim, and it looks pretty good.  Check out the photos.  I must admit that it was MUCH more work than I expected, and I don't want to do that again anytime soon.  Mark
