New toe alignment tool
Started by deathsled, October 29, 2026, 07:52:07 PM
deathsled
Engine revving to disturb
Also, I bought a camber/caster gauge that magnetically holds to the brake rotor hub from a vendor on Ebay.  Was $130.00 or so.  Works well.  The one issue was you either buy a wheel adaptor if you don't have a set of regular steel wheels.
deathsled
Quote from: roddster on October 30, 2026, 12:35:14 PMAlso, I bought a camber/caster gauge that magnetically holds to the brake rotor hub from a vendor on Ebay.  Was $130.00 or so.  Works well.  The one issue was you either buy a wheel adaptor if you don't have a set of regular steel wheels.
Caster/ camber a bit above my proverbial pay grade. I need to work up to that. Shims and the like can be tricky I understand, especially when th car has the Arning drop.
