Build Sheet Question - Leaf Springs
Started by 69 GT350 Vert, June 16, 2026, 10:08:08 AM
Ed there is a guy working on this now
I can send you his contact
Does anyone know how the C9ZX springs were marked?
Dennis Y
Bob --- sorry, maybe I mis-phrased my question as I did not know if anyone had the measurements for the Boss 302 springs and was just musing which springs were made first.
Jeff --- what is the early build date of your Boss
Ed --- looks like Shelbymann1970 also has a SMS lower leaf that he is using with his person to reproduce.
Gary -- keep us up to date with your endeavor. I"m sure a lot of us would be interested.
To all --- thanks to everyone for their input. I have seen this topic come up a few times over the years and just seems to loose steam for whatever reason. Hopefully this time a solution can be found.
I know I lack a lot of the knowledge of most on here but just trying to participate and help find answers
Thank you all!.
sg66
Quote from: Dennis Y on August 12, 2026, 08:12:24 PMBob --- sorry, maybe I mis-phrased my question as I did not know if anyone had the measurements for the Boss 302 springs and was just musing which springs were made first.
Page 25 of this Spring Research version has the 1970 B302 measurements. https://springresearch.org/pdf/volume_18.pdf
These were written specifically for aftermarket manufactures to build to OEM (or very close) specs. Note that the B302 spring is assigned the same 42-503 number as the GT 350/500 replacement however the free arch of the the OEM is 1/4" different.
I have no doubt the OEM springs are visually different as pointed out already.
Quote from: Special Ed on August 12, 2026, 04:59:49 PMWe were working on the s9ms springs back when chris brown passed RIP ole buddy and chris had a machine shop making the unique lower flat leaf and stampping the #s since the rest of the spring can be found from other springs. I sent an odd s9ms lower leaf i had here to chris but not sure if i got it back but if someone wants to finish making the spring i can loan my s9ms leaf out.
got a local guy who wants to see my spring to make some up. The guy who is the " middle man" owns a 70 drag pack car he bought early 70s and bought new springs (D0) and all the cables and battery tray for boss 9 to put a trunk mounted battery into his 70 when he worked the parts counter at a ford dealership. Realized decades later the D0 springs he out on are not correct so his friend is embarking on making some springs. This Shelby owner when he worked at GM gave Max thousands of fastener blueprints so AMK could do GM fasteners.
Tor
My car 48-1014 produced 21 of february has the S9SMS-556A springs
Tor
69 GT350 Vert
I'd like to get my 5RS68 springs re-arched if anyone is is still doing it.  It probably won't be permanent but it should help reduce sagging for a few years.
Quote from: 69 GT350 Vert on August 13, 2026, 07:21:42 AMI'd like to get my 5RS68 springs re-arched if anyone is is still doing it.  It probably won't be permanent but it should help reduce sagging for a few years.
We have several places in KC that do re aching of leaf springs. I would double check in your area with the truck repair community for spring re-arching. I get the impression it is still a widely available service.
I'm lucky as I have  Eaton Springs " in my backyard".
Dennis Y
Hey 69 GT350 Vert, what number is your car? I am trying to figure out which ones should be on my car. I bought it back in 86 while I was still living at home and tore it apart in 88 before cell phone cameras (I think) and had no idea that they were different than a stock Mustang spring. For a number of years after that some of the parts of the car were there and some were here until I got my garage built here. I don't know what happened to them as I was also running a small block Maverick back then and don't know if my dad figured they were scrap or what but unfortunately he was not a big fan of my car addiction. Anyway, just trying to figure out which ones I should have if anyone is sucessfull in getting an accurate copy made. Thanks, Dennis
69 GT350 Vert
#100.  I'm not sure if the 5RS68 leaf springs is an early/late thing.
Quote from: 69 GT350 Vert on September 01, 2026, 09:37:55 PM#100.  I'm not sure if the 5RS68 leaf springs is an early/late thing.
Yes, the 5RS68 leaf springs are typically an early production thing.
Quote from: Dennis Y on September 01, 2026, 08:17:48 PMHey 69 GT350 Vert, what number is your car? I am trying to figure out which ones should be on my car. I bought it back in 86 while I was still living at home and tore it apart in 88 before cell phone cameras (I think) and had no idea that they were different than a stock Mustang spring. For a number of years after that some of the parts of the car were there and some were here until I got my garage built here. I don't know what happened to them as I was also running a small block Maverick back then and don't know if my dad figured they were scrap or what but unfortunately he was not a big fan of my car addiction. Anyway, just trying to figure out which ones I should have if anyone is sucessfull in getting an accurate copy made. Thanks, Dennis
The problem I see is that the S9MS Shelby leaf springs are unique and besides the bottom special leaf the next two leaves are different lengths compared to a regular Mustang or Boss leaf. I think I read where one of the members was trying to have just the bottom special leaf made which is better than nothing but still not correct.
Dennis Y
Bob, do we have any info as to when (either by date or car#) the change from 5RS68 to S9MS occurred?
Hey 69 GT350 Vert, could you possibly get measurements of you middle 2 springs to see how they compare to the S9MS ones that Bob has measurements for to see if they are similar?
Anyone else out there with the 5RS68 springs, could you post your car # and build date if you have it to add to our info?
THANKS!
69 GT350 Vert
I don't have access to my car for a while.  I'm not sure measuring springs installed on a car will be helpful.  My springs have sagged a bit.
I can do some measurements when I get the car back.
Quote from: 69 GT350 Vert on September 04, 2026, 08:31:51 PMI don't have access to my car for a while.  I'm not sure measuring springs installed on a car will be helpful.  My springs have sagged a bit.
The length of the springs should not be different sagging or not.
