8T02S143449-01576 on BAT
Started by 5s386, August 14, 2026, 08:54:02 PM
azdriver
Nice car... it seems they put the steering box tag on the rear axle???
Pat
Thats what they did! Good catch.
WT6066-2600
Did all 68s have rear axle snubber brackets?
"#1 fan of theCoralsnake.com"
Not to be confused with the 67 Shelby leaf spring snubber bracket.
Quote from: WT6066-2600 on August 15, 2026, 06:09:15 AMDid all 68s have rear axle snubber brackets?
I think you were going for pinion snubber bracket. ;)
WT6066-2600
Sorry wrong nomenclature, so this $140k restoration is missing the bracket?
It is and a few other things, like spacers under the fog lights, the smog, the spare, the buck tag and a bunch of other knick knacks
WT6066-2600
$140kjust doesn't go very far anymore!!
KR500
GOAT12
The pinion snubber bracket looks to be integral to the pinion housing, which I thought Ford did not start until around 72. Were the 68's a bolt on pinion snubber??
Quote from: GOAT12 on August 17, 2026, 03:05:35 PMThe pinion snubber bracket looks to be integral to the pinion housing, which I thought Ford did not start until around 72. Were the 68's a bolt on pinion snubber??
Not on this application/those rearends.
But the cast pinion retainers with the snubber hood or contact feature was part of 8" rearend center sections since the early 60's
