GT500 oil filter adaptor
Started by csheff, June 11, 2026, 11:50:24 AM
csheff
What are the correct pieces needed on the top for the line going to the gaugees? Are they just plain brass connectors? Is there a kit u can get anywhere?
Quote from: csheff on June 11, 2026, 11:50:24 AMWhat are the correct pieces needed on the top for the line going to the gaugees? Are they just plain brass connectors? Is there a kit u can get anywhere?
The fittings are steel plated zinc silver not brass. The fittings consists typically of 3 pieces. You can not get a kit just anywhere. As an alternative you could plate the brass fittings zinc silver to mimic what the steel fitting looks like.
csheff
Thanks Bob
csheff
Anyone know where to source the two correct fittings and oil line for the oil filter adapter?
Quote from: csheff on July 07, 2026, 08:08:31 PMAnyone know where to source the two correct fittings and oil line for the oil filter adapter?
PM sent.
