Big Block Shifter Reverse Rod Help
Started by brandosaac, June 17, 2026, 06:48:48 PM
brandosaac
Question ;
 I Did a moch up install of a 68 big block shifter on a Mustang toploader with C7OR mid position tail and FE kick back plate.
Im wondering if the reverse rod is supposed to have this appx 3/4" upwards bend near the middle ???
Also, am I correct in thinking that rods and levers were the same on big block / small block? ,
I realize that big block mixing box was slightly different with the reverse lever angled back
Any info is good info, thanks
