Power steering hoses
Started by garyrandles, April 02, 2026, 12:38:09 PM
garyrandles
Trying to find power steering pressure hoses for my 67 GT-350. My valve has small fitting, pump fitting is different than my 69. Any help is appreciated. Pretty mine are original, I've had the car since 1974.
Corey Bowcutt
Have you checked out Blue Dot Specialties, LLC?
Corey
Quote from: Corey Bowcutt on April 02, 2026, 01:24:55 PMHave you checked out Blue Dot Specialties, LLC?
Corey
+1 .The small fitting pressure line was typically used on all regular production 67 Shelby's. I sent blue Dot  samples many years ago to make hose patterns from and they are very close . Although there is a slight difference in the bends between the 67 GT350/GT500 return hose compared to 68 they chose to only make the 68 style. It is a very minor difference and hard to tell unless side by side. With that said they are concours show quality for all but DIV I or MCA Thoroughbred.
