textured taillight panel
Started by cob428, January 29, 2026, 06:14:48 PM
cob428
Was the texture from the taillight panel replicated on the end caps as well or were the just painted semi gloss black to match? June 69 build
Pete
Quote from: cob428 on January 29, 2026, 06:14:48 PMWas the texture from the taillight panel replicated on the end caps as well or were the just painted semi gloss black to match? June 69 build
Pete
Fastback or convert?
cob428
Pete
Fastback had the grained texture and convertible was smooth. Both were the semigloss black. Of course the early production cars had a spray on texture instead of the made into the panel grain effect for the rear panel and endcap.
cob428
This is what I am up against. When I purchased this in 91 you can see PO painted car red. When I had it repainted the inside of the decklid texture was sanded smooth and so were the inner side of the end caps. Anyone ever find a way to recreate the texture for
1) inner flat surface of the decklid
2) texture/grain on the end caps
Pete
Quote from: cob428 on Today at 01:30:04 PMThis is what I am up against. When I purchased this in 91 you can see PO painted car red. When I had it repainted the inside of the decklid texture was sanded smooth and so were the inner side of the end caps. Anyone ever find a way to recreate the texture for
Pete
At least for the end caps grain texture I have seen others replicate the grain by using a piece of grained vinyl material and use it press into a skim coal of bondo. Sounds easier then it is however I saw it done. I understand that it takes practice to get it right given the time sensitive nature of activated bondo.
