New Mod project
Started by 68cobra427, November 13, 2025, 03:12:50 PM
68cobra427
Installed quarter window extensions. Ended up cutting off 1/4 inch off the 1inch tube extension that was welded on. Stuck out to far.
68cobra427
Have the plastic panels fitted and showing window crank location.
68cobra427
Resting the roll bar on the panels showing the top missing it when lowered or raised. Now on to welding the bottom tube to the body so the roll bar will slide over and bolting both together for removal down the road it needed. Like quarter window issues.
Looking good !
Little by little does the trick
Merry Christmas
68cobra427
Merry Christmas as well. Thanks
68cobra427
68cobra427
68cobra427
68cobra427
Fitting new repo dash aluminum pieces. Sending off OEM ones to be restored to put up for sale. All but the heater control plate.
Also took off the orig aluminum, the 4 pieces. When restoring they toss them and put aftermarket ones on.
Red67co
Nice build detail it's the little things that you don't see that makes the difference in how it goes together.
