66 GT 350 automatic transmission information
Started by aboss4tg, December 13, 2025, 05:15:52 PM
aboss4tg
Is there a vin stamped on the automatic transmission housing? I have a 66 Hertz that was converted to a four speed and want to convert back to an automatic. Recently purchased a C4 and noticed a vin or series of numbers stamped on the top side on a flat tab. The one I purchased reads 135920 and not sure if this is a vin number.
Todd
69 GT 350 Hertz
66 GT 350 H
89 SSP
Quote from: aboss4tg on December 13, 2025, 05:15:52 PMIs there a vin stamped on the automatic transmission housing? I have a 66 Hertz that was converted to a four speed and want to convert back to an automatic. Recently purchased a C4 and noticed a vin or series of numbers stamped on the top side on a flat tab. The one I purchased reads 135920 and not sure if this is a vin number.
Todd
No vin on 66 auto trans. Be sure you are looking at a 66 production year C4 case .
Sounds like you purchased a C4 originally from a 68 on up car, truck or van depending on how its equipped or if its been modified for floor verses column shift.
No VIN - however there were differences in the auto trans for the HiPo. The Servo cover is one you can see externally. I think the valve body also had some changes. The "regular" HiPo Mustang and the GT350 used the same trans so nothing Shelby specific to find.
68 up the Feds changed the rules on VINs and where they needed to be stamped. Today you can find the VIN lasered, labeled or stamped into about every part - engine, trans, rear end, fenders, doors, etc. Just about anything a chop shop could sell.
S7MS427
Quote from: 98SVT - was 06GT on December 13, 2025, 07:08:17 PMNo VIN - however there were differences in the auto trans for the HiPo. The Servo cover is one you can see externally. I think the valve body also had some changes. The "regular" HiPo Mustang and the GT350 used the same trans so nothing Shelby specific to find.
+1. The Hi-Po C4 for a 1966 Hi-Po Mustang is a rare beast indeed. If you can find one, expect to pay a substancial premeum over that of a standard C4.
There were three major differences made by Ford between the high performance C4 and the standard unit that was used with all other non-Hi-Po cars:
  • Valve Body — The throttle pressure boost valve spring and intermediate servo accumulator spring were lighter and the separator plate had two holes that were enlarged, one from 0.047 inch to 0.070 inch and the other from 0.125 inch to 0.188 inch.
  • Intermediate Servo and Cover — The intermediate servo was larger which provided additional area for the piston face and subsequently more force on the intermediate band which resulted in better 1-2 shifts.  This servo is identified by a large cast "C" on the cover rather than the "A" that the standard Mustang C4 used.  The "A" servo piston is 2.84 inches in diameter and the "C" servo piston is 3.13 inches in diameter.
  • Governor — Ford changed the secondary valve in the governor by reducing the weight from about 19 grams to 12 grams, 37% lighter.  This moves the wide open throttle shifts points into the 5800 RPM range.  Contrary to what has sometimes been reported, Ford DID NOT install a lighter spring in the governor to achieve higher shift points.
Good luck in your search, if you find more than one, please let me know as I've been looking a long time for one I can aford. I don't htink that is likely to happen, but I have to ask...
Roy Simkins
1966 G.T.350H SFM6S817
1967 G.T.500 67400F7A03040
aboss4tg
TY for all your response to my question. I purchased the transmission from a friend that had it rebuilt and never installed after rebuilding. Should be a good start for the short term until I can find an original.
Can a C4 be built with all the parts that make it a HI PO?
69 GT 350 Hertz
66 GT 350 H
89 SSP
Contact Roy in the posts on this subject he has extremely detailed drawings and modifications to make a c4 for a HiPo
Quote from: aboss4tg on December 14, 2025, 06:27:24 AMTY for all your response to my question. I purchased the transmission from a friend that had it rebuilt and never installed after rebuilding. Should be a good start for the short term until I can find an original.
Although genuine hipo trans is preferred it is definitely problematic to find. Building a hipo trans out of a generic C4 is the most practical way . Parts, tags etc. are available to make the conversion to similar performance and the look good enough for concours. That is if that is your goal.
S7MS427
Quote from: Steve McDonald Formally known as Mcdonas on December 14, 2025, 07:01:16 AMContact Roy in the posts on this subject he has extremely detailed drawings and modifications to make a c4 for a HiPo
Thanks, Steve. However, you were also a big help on this project.
Quote from: aboss4tg on December 14, 2025, 06:27:24 AMCan a C4 be built with all the parts that make it a HI PO?
aboss4tg, Check out the GT350H section of my website for a narative of how I converted a plain jane C4 out of a '67 Mustang to serve duty in my GT350H. Much credit for this information goes to Bob Mannel for his amazing book "Mustang & Ford Small Block V8, 1962-1969" (RPM Press, 2014) as well as others that are listed in my atricle. Link to my website is in my signature.
I would say that a 1966 transmission is the best to start out with as there are some minor differences between that one and the 1967 version I used. If you are using a transmission out of a '65 or '66, the shift kit from Transgo will be different than the one I used. Good luck and please let us know how it goes. You may contact me privatley if you think that will help.
Roy Simkins
If your going to make one remember there are running changes you should consider since not all Hipo 66 C4's look the same in every detail.  There are threads already on the site that go into depth on these.
aboss4tg
A lot of good information everyone has provided. Considering looking for a 66 transmission and will try and update when I get started.
Todd
69 GT 350 Hertz
66 GT 350 H
89 SSP
warwick
Bob Mannel also wrote an article specifically on 289 HiPo C4 Automatic in Fairlaner May/June 2007. It offers substantial detail. Bob is prob on this forum.
As an owner of an orig 66 hipo C4 I would say they are different-I would say shift points are above 5800 and they only stay in first if selected, otherwise they shift out of first very very fast.
Quote from: warwick on December 15, 2025, 05:34:14 PMBob Mannel also wrote an article specifically on 289 HiPo C4 Automatic in Fairlaner May/June 2007. It offers substantial detail. Bob is prob on this forum.
Bob is a member here but hasn't posted for several years, a PM might work. He does post occasionally on the HiPo forum. If you join the Fairlane Club of America you have unlimited access to Fairlaner magazine back issues including the May/June 2007 issue mentioned above. Also, if you have the digital version of Bob's SBF book, Appendix 1(a) has details on the HiPo C4, the printed version doesn't have this.
S7MS427
I did develop the information presented on my website in part from both of those sources. Taken together, I think they form a pretty complete picture of the differences between the non-Hi-Po transmission and the Hi-Po. The background information on how this rare beast came to be is interesting.
Roy Simkins
Quote from: S7MS427 on December 17, 2025, 09:55:57 AMI did develop the information presented on my website in part from both of those sources. Taken together, I think they form a pretty complete picture of the differences between the non-Hi-Po transmission and the Hi-Po. The background information on how this rare beast came to be is interesting.
I just finished reading again the C4 info and rebuild timeline you created. It was very enjoyable and should be a tremendous help for others. Thank you for the effort. Great job.
