Tach Installation for 66 Shelby
Started by hertz350, November 26, 2025, 12:42:35 AM
hertz350
Has anyone installed a Shelby Tach on the dash without removing the windshield? I would like to know how that was done.
How did Shelby American install the Tach?
GT350Nick
Quote from: hertz350 on November 26, 2025, 12:42:35 AMHas anyone installed a Shelby Tach on the dash without removing the windshield? I would like to know how that was done.
Do you mean just just screwing it down into the existing holes or drilling and mounting it into a new/replacement dash pad?
JFriend
Following. I replaced he dash pad in my '66 H, but haven't located an appropriate tach yet, so I hadn't considered that there would be any difficulty in mounting it. I still have the original dash pad for location info.
When we acquired our 1966 GT350 we had the tach refurbished, going from memory the top-mounted tach had two sheetmetal screws holding the bracket down and the wire disappeared through a hole in the dash pad which was concealed by the tach bracket.
Best of luck on your endeavors!
SA removed the das pad and notched the metal dash structure
Are you wanting to know how it was done on a car at SA that had never had one installed before or are you asking about a GT350 that needs the tach mounted and reinstalled after restoration? One procedure is much harder then the other. Nether need the windshield removed.
hertzz350
Also be sure you install the metal hollow tubes into the screw holes to prevent the bracket from crushing the dash pad you see on a lot of shelbys. Cut the tube so it is almost flush with the bottom of the tach bracket. The tubes are just large enough for the screw to go into. When you screw it down it will be nice and secure.
current owner of 6s689
Previous owner of 6s1855 ,6s1297,6s731
Funny that you mention
Quote from: hertzz350 on November 26, 2025, 01:07:23 PMAlso be sure you install the metal hollow tubes into the screw holes to prevent the bracket from crushing the dash pad you see on a lot of shelbys. Cut the tube so it is almost flush with the bottom of the tach bracket. The tubes are just large enough for the screw to go into. When you screw it down it will be nice and secure.
Funny that you mention a "tube"
I believe when we removed our tachometer and bracket, there was a short piece of steel tube or pipe.
Then when the bracket gets bolted down, the pipe prevented crushing the dash pad and prevents the tachometer from moving or wobbling.
hertz350
Thank you all for the responses. I will be installing a tach on the dash of a 66 Fastback which has not had a Shelby tach installed before.
In my 66 Shelby we installed the tach using the existing holes before we installed the windshield. We had plenty of room to work with. I was looking for tips on how to install one including drilling the holes in the dash metal while the windshield was in place.
I was also looking for information on how SA did it?
greekz
You might try a right angle drill adaptor.  If I could figure out how to attach a picture, I would.
SFM 6S1134
'67 GT-350 #2339
'65 Fairlane Station Wagon
2002 T-Bird (since new)
'25 Explorer ST
Quote from: greekz on November 26, 2025, 06:49:59 PMYou might try a right angle drill adaptor.  If I could figure out how to attach a picture, I would.
You can get a inexpensive right angle drill given a one or two time usage at Harbor freight. If plan on using a lot then a better ones makes more sense.
