Headlight wiring harness clips / routing
Started by Justin1967gt500, November 12, 2025, 02:06:41 PM
Justin1967gt500
Hello!   Is there a certain routing of the headlight harnesses or special clips that were used?   Thanks!!!!!!
Quote from: Justin1967gt500 on November 12, 2025, 02:06:41 PMHello!   Is there a certain routing of the headlight harnesses or special clips that were used?   Thanks!!!!!!
If you are referring to high beams then yes. That would have to do with the date when your car was converted at Shelby. Build date would help and also Shelby sequential number so as to determine which type was used on your car.
As Bob stated above the date your car was completed at Shelby American would be important and confirm you are referring to the headlights in the upper grill area, and are you referring to inboards or outboards.
There are some plastic clips used by Ford for the stock Ford Mustang portion(s) of the wiring across the lower area of the radiator core support, those are available through AMK or NPD and others sellers.
There were some plastic "clip/holders" used on the inboard cars after a certain time, they were stuck (adhesive) to the sides of the hood support bracket by Shelby workers.  One of the SAAC club members was having those 3D printed but the company "lost" the program and wanted to charge him to make it again so they could fill another order and he refused (I don't blame him, I have a similar story).  I think those are shown in one of the links below.
Here are some links to threads in the '67 Shelby section that might help;
https://www.saac.com/forum/index.php?topic=24554.msg183038#msg183038
https://www.saac.com/forum/index.php?topic=18796.msg149755#msg149755
https://www.saac.com/forum/index.php?topic=16787.msg135829#msg135829
