GT500 Harmonic Damper
Started by csheff, May 21, 2025, 04:28:25 PM
csheff
What is the correct damper for the 67 500? I have one with numbers on the top D5TE-DA, is this correct? If not what do I look for? Thanks
TA Coupe
D5 indicates 1975 and I believe TE would indicate truck but not positive about that?
     Roy
If it starts it's streetable.
Overkill is just enough.
Quote from: csheff on May 21, 2025, 04:28:25 PMWhat is the correct damper for the 67 500? I have one with numbers on the top D5TE-DA, is this correct? If not what do I look for? Thanks
C5TE-DA is not even close IMO.  C6AE-A is the assemblyline part. Cobra Automotive made a repro up that is close.  https://store.cobraautomotive.com/1967-ford-428-police-interceptor-shelby-gt500-harmonic-balancer-c6ae-6312-a/
csheff
Thanks guys. Didn't think it was right as I have had it a long time.
csheff
Bob do u know a good place that repairs the damper's Rubber replacement?
I have not personally used them but have heard many positive accounts from friends and others using Damper Doctor.  http://www.damperdoctor.com/
csheff
Correct part # C6AE=6316-A? or 6312-A
Quote from: csheff on May 21, 2025, 10:49:17 PMCorrect part # C6AE=6316-A? or 6312-A
The part is C6AE-6316-A. The 6312 must be a typo because the 6316 is the part of most balancers base part number.
JWH
Hi Craig, I had an original damper for our GT500 restored by The Damper Doctor. A guy named John Wyss in Redding, CA.
(888) 834-2137  damperdoctor.com
      This was back in 2019 and I am still very happy with their work. So at least one place for you to consider.
Jeff
csheff
