Distributor Vacuum Control Valve
Started by 69 GT350 Vert, May 04, 2025, 01:08:24 PM
69 GT350 Vert
My 1969 shop manual shows for a 351W without AC, there is not a distributor vacuum control valve in the waterneck.  Is that correct?  I thought all cars had one.
It looks like the distributor vacuum advance in my 69 GT350 was designed to receive full manifold vacuum.  Not ported/timed vacuum.
Quote from: 69 GT350 Vert on May 04, 2025, 01:08:24 PMMy 1969 shop manual shows for a 351W without AC, there is not a distributor vacuum control valve in the waterneck.  Is that correct?  I thought all cars had one.
The thermostat housing has the opening for the vacuum switch but it has a plug put in it from the engine plant.
69 GT350 Vert
Automatic. Early car #100 built in December 1968.
I think it should have vacuum port.
See bottom of page
http://www.thecoralsnake.com/K211S.html
No ac no tree, ac gets tree, 1970s were updated
Quote from: Coralsnake on May 04, 2025, 01:52:57 PMI think it should have vacuum port.
See bottom of page
He has a 1969 GT350 without AC - I think his car has a plug in the water neck and no vacuum control valve.
Bob, it should have a square plug. No vacuum tree.
My mistake no AC no port in 1969 for his application
69 GT350 Vert
Thanks guys.  I will have to find the correct size square plug.  I have an allen head plug in there now and it bugs me.
