Cobra backwards shifter question
Started by brandosaac, February 15, 2023, 04:43:50 PM
brandosaac
on a 427 cobra with toploader and factory ford shifter assembly ,
If the stick is mounted backwards, the reverse lock out lever (tab) that slides up and down is now on the wrong side and wont work properly.
Is there a reproduction chrome stick specifically made for this application where the lock out is switched to the other side?
brandosaac
thanks, but that wont bolt on to a stock ford mixing box
Just cut a new slot for the pin @ 180 degrees.
