Vintage GT1 Mustang - $7000
Started by 98SVT - was 06GT, September 03, 2022, 12:59:46 PM
The car has a Speedway Engineering chassis with a 3 link quick change rear end and watts link. There is an extensive use of Tilton products. 3 disc clutch, starter, hydraulic clutch release along with brake master cylinders. JAZ Brake calipers use the same internals as Wilwood. The engine is a Ford Motorsport XE NASCAR pillow block. It has a billet steel crank producing est. 650 h.p. from 310 cu.in. The cylinder heads are Ford Motorsport A3 aluminum tall port with stainless rockers Titanium retainers and stud girdles. Carillo rods and Venolia pistons. Dry Sump with custom Olsen pan and a preheater in the oil tank assures no oiling problems or long idling sessions. MSD crank fire ignition and 8,000 limiter chip allowed this package to be clocked at 170 mph on Willow Springs front straight. The car raced originally at Willow Springs, Buttonwillow, Laguna Seca and Sears point. It had several podiums.
When the car was purchased it lacked several parts. I have purchased some but you will need to get a Ford Toploader, shifter and a drive shaft. There is a new aluminum 850 CFM Holley Track Warrior Carburetor with proper AN fittings included. A current FIA rated seat is included with new mounting brackets. You'll need to get your preferred brand of belts. There is a new GM one wire alternator. The Fuel Safe bladder should be replaced I'd run one of the poly cells in the existing Fuel Safe housing. You'll need a windshield (stock glass or 5 Star Racing). The car was missing its 12x16 front wheels when purchased. Since it was to be a track day toy I purchased 8 - 15x10 NASCAR wheels and 16 new/used tires which should be good for a couple years of fun – or until you want to run 11/10. The car has custom cross over headers. To meet Laguna Seca noise limits 2 large Flow Masters were added and the exit was moved under the car. The SN95 body is complete and an entire set of body molds is included.
Also available (only with the car)
2020 Carson California open trailer with tongue box, 2 5/16 coupler, spare, xtra wide, 4 D ring tie downs  $3,100
https://www.carsontrailer.com/trailers/car-haulers/california/
TKO 600 Trans .82 5th, converted to Dog Box $1500 - you'll need to change to 26 spline clutch discs to use this trans.
2 gallons Eastwood Electric Yellow paint w/ reducers and hardeners $280
Car is SCCA legal for GT-1 and meets SVRA specs for their Group 10/GT2 with spoiler or GT4 with large wing
Possible trade +/- cash for?
Photo: This is the current body on the car. My car had a new body and when the owner crashed his car he swapped it onto his. He put his old body on my chassis. The nose and hood currently on it are different colors 2nd photo is as purchased (complete body + molds included).
More pictures or info: Brett Mac Donald bmacd68@yahoo.com
