6 Things That Make Living with a Carburetor Easier
Started by FL SAAC, May 06, 2024, 04:41:45 PM
1 - Use Clean, Non-Ethanol Fuel
    (Good luck on this one)
Although ethanol-blended fuel does have big power potential, it is also the root of more than a few headaches for those of us with a vintage bent. Gasoline will evaporate at the temperatures most of us like to cruise in, and that means the gasoline disappears and leaves the residue of the ethanol behind. It clogs the multitude of precision passages that make a carburetor function. Most carb tuning and advice is rooted in pre-ethanol times, so even using jetting and setup advice can be tough, as ethanol fuel behaves differently compared to "pure" gasoline.
2 - A Well-Tuned Choke
Listen to the arguments against carbs, and cold starts are oft cited as being a runaway victory for fuel injection. It's a fair point; fuel injection has won the smooth-running game handily, but a well-tuned choke on a carb works really well considering how simple it is. After all, it carried us through when our hobby cars were simply daily drivers.
Thermostatic chokes often use a bimetallic coil, which is just two different metals bonded together that expand differently when heated or cooled. Pump the throttle once before starting the engine to set the choke, and the engine should start and set at a high idle. Consult your shop manual to get exact settings. Tuning a choke can be finicky, but when it's all sorted, there is nothing quite like a smooth start-up on a crisp fall morning.
3 - Happy Distributor
A professor of mine from college once told me "90 percent of your fuel problems are ignition." People will be chasing "carb problems" for hours before realizing the damp spark plug that seems to be running too rich is actually just a plug getting weak spark or not firing at all. Keeping the ignition in top shape helps to keep many other components running smoothly—and it also assists with diagnostics for rough running.
4 - Smooth Linkages
Binding linkages can make chokes stick and accelerator pumps function inconsistently. It's wild to think that the carb's exterior cleanliness is just as critical as its cleanliness inside. Road grime is attracted to oily or damp surfaces, and it only takes a small amount of oil mist from an open breather or leaky gasket to attract a surprising amount of junk, which will damage small seals or gum up finicky linkages.
5 - Clean Air
It seems there are actually three sides to a carburetor: the fuel side, the air side, and the outside. Does that make sense? Maybe. Regardless, the air coming into an engine is the easiest pathway for all the stuff that should stay outside of an engine to get inside of it. Dirty throttle blades and intake manifolds can cause interesting problems in both carbureted and fuel-injected engines. All the delicate and small air passages that help keep carbs balanced and flowing can get clogged quickly. Keep an air filter on the intake, and your carb will be happy for a long time.
6 - get a new performance vehicle with electronic fuel injection that can run on cat piss and has at least a five year warranty
Best Wishes  and  Happy Motoring  !
Living RENT FREE in your minds
All Time Post Count King !
Home of the "Amazing Hertz 3 + 1 Musketeers"
FL SAAC Simply the Best, much Better than ALL the Rest.
I am certainly not a Shelby Expert
I take exception to your "anti-feline" rhetoric. Cats are good people. Leave them alone. Fascist.
We love cats,  here is ours...smiling because we just adjusted our carburetor to perfection
And especially on the BBQ
Chris Thauberger
Here are six thing that make reading these self proclaimed non expert post better...
Being the "All time post count king" on a forum is kinda like being rich in Monopoly
Life is 1% what happen to you and 99% how you react to it.
Video: Gold Concours GT500
TA Coupe
My cats piss is pretty potent. A few drops in a tank of gas will make a car purr like a kitten and I'z got plenty of cat piss to go around.
      Roy
If it starts it's streetable.
Overkill is just enough.
Quote from: TA Coupe on May 07, 2024, 08:18:25 PMMy cats piss is pretty potent. A few drops in a tank of gas will make a car purr like a kitten and I'z got plenty of cat piss to go around.
      Roy
Duly noted on comment # 6
Drew Pojedinec
The issues I chronically see:
-boiling fuel, fuel lines 2 inches from a header
-timing at 5 bdc while using a modern cam
-setting carb on engine, never tuning it.
Quote from: Drew Pojedinec on May 09, 2024, 10:30:17 AMThe issues I chronically see:
Excellent points by Mr. P
Thank you
