68 GT500 Engine details and installation.
Started by Milo, March 20, 2020, 11:41:17 AM
Milo
So, I have some time on my hands these days... Yay, quarantine
Wondering if anyone has detailed photos of a 68 PI together on a stand just before install? I'd love to have an out-of-the-car reference, if possible.
Also, what is conventional wisdom when it comes to installing components on the engine and inn the engine bay before dropping the drivetrain back in? I've never reinstalled a BB motor/trans, only SB's which have all the room. Can I sneak the drivetrain in with the brake booster and master preinstalled? Any other best practices I should know?
Any wisdom and imagery from your vaults would be greatly appreciated! I WILL get this car back together during this CA lockdown.
With the communities blessing, I'd like to exercise humility and operate with the motto that "there are no stupid questions". I've feel like I've done my research and I have *most* of my ducks in a row. Admittedly, one major mistake I made was during disassembly - 2 or 3 years ago now - I went light on pictures. Foolishly, I expected the engine rebuild to be done in a matter of weeks (based on past experience with the builder) and that turned into a year and a half... so my memory is very, very faded.
So, I ask - would a single thread be the best way to ask all of my questions, would you rather I bombard you with individual posts, or keep my mouth shut and let my ego wing it?
1972 Bronco Coyote
1968 F-250 Camper Special 390
Chris Thauberger
Leave the booster out. Notice the use of cardboard and foam rubber matting.
She's tight but it fits.
Have a look at this while I find a few pictures for you.
https://youtu.be/w4iS2vaA79I
Being the "All time post count king" on a forum is kinda like being rich in Monopoly
Life is 1% what happen to you and 99% how you react to it.
Video: Gold Concours GT500
Chris Thauberger
This is what I was able to find quickly.
Let me know if you need something specific and I can look through what I have.
IIRC these were from a group of photos I posted for everyone to critique before I installed it in the car.
If you would prefer Hi-res I can always email you.
Chris
I like that bra-clip on the vacuum hoses. Where do you get them?
68blk500c
Way to go, Chris!  I am adding two photos that show my PI dripping wet to give a different look at the process.
Good to see progress, Milo.
Don
Can anybody document the red on the dist advance? Don't recall seeing that on a 69 anyway is that a 68 thing?
Chris Thauberger
I think I bought that distributor from Bob G, I can't remember anymore bought way too many parts.
Side-Oilers
I realize why Ford did it at the factory (easier) but does painting the water pump bypass hose weaken it in any way?
Wouldn't a rubber hose prefer to be unpainted?
Current:
Previous:
1970 Ranchero GT 429
1969 LTD Country Squire 429
1963 T-Bird Sport Roadster
1957 T-Bird E-model
The bypass hose was a special thicker wall high pressure type hose not a piece of heater hose like I have seen many people use that ends up swelling up from the heat and water pressure.
Quote from: Chris Thauberger on March 20, 2020, 04:44:50 PM
Sorry I don't remember selling it . Must have already been on the advance if I did because I have not had a reason to mark a advance in that way .
Quote from: Special Ed on March 20, 2020, 05:15:18 PM
+1 . To add  - painting it will not adversely effect it.
Side-Oilers
Current:
Previous:
1957 T-Bird E-model
Milo
This video is AMAZING. I do love how easy a time lapse can make an install look.
The cardboard and foam rubber matting is brilliant, as is the use of the ratchet strap to get that extra tilt... noted and noted. What were the straps that you used to connect to the engine hoist leveler? They look a bit like the wheel tie-downs I have for towing, but I'm sure yours are longer than what I have. They look a lot easier to work with than the alternative.
Also, glad to see I wasn't crazy for wanting to attach the first run of the exhaust to the manifolds before install.
Do you happen to have any photos of the engine bay with the engine out? Want to make sure i get the firewall area right before I lose most of the access.
Quote from: Chris Thauberger on March 20, 2020, 11:58:10 AM
1972 Bronco Coyote
Milo
#13
So, I mocked it up today. Any comments or corrections? Like maybe how to rotate images...!
1972 Bronco Coyote
Milo
Also, does can anyone tell me what these few pieces are for?
1972 Bronco Coyote
