replacing wing nut bolts that hold air cleaner plate
Started by Copescobra, March 02, 2022, 11:23:20 AM
TA Coupe
Here's a link to the bases that I have.
http://www.saacforum.com/index.php?topic=16457.msg133607#msg133607
I also have another 2X4 One that has a small pad area on the inside but no holes. Bob can you tell me what my single 4 bottom goes to and if it is original?
    TIA  Roy
If it starts it's streetable.
Overkill is just enough.
Quote from: TA Coupe on March 03, 2022, 10:22:37 PM
    TIA  Roy
Reply #17 of your link shows a original later 68 single four base . A 67 Shelby dicast base service or modified because it is missing he fitting. The other two bases only show the top side .I can't tell for sure until I see the bottom side of both.
TA Coupe
Pictures of both the top and the bottom are in that link.
Roy
Quote from: TA Coupe on March 03, 2022, 11:26:25 PM
Roy
I see them now in #18 . Yes they look like they should.
Copescobra
Thanks everyone for your input.  I found my wing nuts.
When I removed them I had forgotten I put them in a safe place.
So safe I couldn't remember where until a passenger in my truck noticed them
in the armrest pocket.
1969 SCJ 428
1970 Boss 302
2012 Boss 302
Quote from: Copescobra on March 28, 2022, 12:30:16 AM
